Hexagon's Dynamic Geometry Smoothing question
Is there a way to use the smoothing function on the Dynamic Geometry without adding polygons?
I figured out how to use the sub-tree under Dynamic Geometry while Smoothing is temporally applied, and move the vertices to match up where projected location would be under smoothing.
Though that saves a little time then trying to smooth vertices by eye, it's still time consuming.
Is there a way to make the vertices snap to the smoothed vertex locations?
Post edited by Basis on
No. Smoothing adds polygons. All the vertices that would be created are not visible to move around until the geometry is collapsed.
