How to distinguish G3 and G8 items, materials, etc. in one product?
Maybe I just don't know how to use the DAZ studio properly, but is there a way to distinguish which item, material, etc. in a product that is both for Genesis 3 and Genesis 8 is supposed ot be which generation, please?
I bought Nicole: https://www.daz3d.com/nicole-for-genesis-3-and-8-female-s
When I open the item, it shows two identical figures, both called "Nicole". Almost all other items have two identical versions. Based on experience with other such products, saying something like the one on the left is G3 and the one on the right is G8 simply does not work reliably. Sometimes the order is swapped.
Am I doing something wrong? Is there some sort of a settings options I didn't find? How do I know which item is for which generation, please?
If you're opening it from smart content, you want to click on the info tab to open it up. That will show the installation path and you'll be able to tell if it's G3 or G8. In the attached example, the path shows that the selected figure has been installed in the Genesis 3 folder within the DAZ library.
Thank you very much @FenixPhoenix, that was it. I somehow had that tab minimized and I couldn't see it.
