Oops, what did I click to make my figures invisible when I'm on the Surfaces tab? Fix needed.
Hi, silly question here. When I used to go over to the Surfaces tab, I could see my figures and their clothes, but I think I clicked something unintentionally. Now I no longer see my figures, only the white selection brackets. How do I go back to the original view? Thank you.
--MW
The 'usual suspects' would be the 'visible' button in scene tab (the little eye icon or setting opacity to 0 in surfaces.
Hi, I verified, and I indeed have the surfaces visible and all the opacities > 0. It's just that everything disappears when I switch over to the Surfaces tab. Very weird...
--MW
Did you change the view mode by accident?
Do you see your images in Texture Shaded mode before you change to the Surfaces pane? If so, it could be a graphic card issue.
Hi, yeah, I think I changed the view mode. I just don't know where I can change it back! I doubt it's a graphics card problem...I think it just happened because of a misplaced click...
--MW
Texture Shaded is what most people use, see below:
Ah hah, thank you for the screencap. As you probably guessed, I had turned off texture shaded view for my Surfaces tab and put some other view there instead. I reverted it to texture shaded, and all is well. I appreciate your help.
--MW
You are most welcome :)
