Missing files Anastasiya
reserv888reserv888 Posts: 1,150
I just bought Aiko 5 and Anastasiya for A5. When I load the figure (Anastasiya) i get this error message:
"/data/DAZ 3D/Genesis/Base/UV Sets/DAZ 3D/GenePool/Stephanie 5.dsf is missing".
I don't have Stephanie 5 and it doesn't say anything about Stephanie in the requirements.
Is the error message wrong or the requirement specs?
  • Richard HaseltineRichard Haseltine Posts: 102,740
    edited February 2014
    Are there any obvious problems? It's possible that the materials were saved using the S5 UV Set on an area in which it is the same as A5, and probably the others, in which case it's annoying (and should be reported to DAZ, via a support ticket) but harmless. However if there are areas where the maps don't join correctly then that would be a more serious problem.
  • reserv888reserv888 Posts: 1,150
    There is no obvious problem. But on the other hand I don't know how it is supposed to look, If the texture, color, shape or something else should be different.
    But as said. No obvious problem like the one you describe.
    The error is about a missing UV Set, so it would affect the way the textures applied to the model if it did anything.
    Ok, Richard. Thank you.
  • SloshSlosh Posts: 2,391
    I just loaded up Genesis and tried all the Anastasiya presets... none of the material zones uses Stephanie 5 uvs, no matter what preset was applied, so that's not the problem in this case. However, if you load Anastasiya via the "Actor" preset that comes with the product, it does load Genesis, with the Anastasiya shape and it DOES set the Tear and Iris material zones to Stephanie 5.
    Until it is fixed, if reserv888 simply ignores the warning, the figure will still load. He/she may then apply the presets and the product will work just fine.
    Thank you Slosh.
