Character turns to gray blocks when I try to pose it
in New Users
I think I hit a button somewhere. When I try to make any changes the character turns into a stack of gray blocks. It's fine for bigger poses but if I try to make any adjustments to the face I get a big gray block and can't see anything.
Any help would be greatly appreciated.
Thank you
1290 x 1003 - 113K
1292 x 982 - 109K
On the Draw Settings tab, check if the Manipulation DrawStyle is set to Bounding Box. If so, change it to Use Current (which is whatever mode the viewport is using).
Wow! I can't believe it was that simple. I don't remember even opening that box. As a newby I was probably looking for something else.
Really appreciate it.
Simple, but you have to know where to look...
