Superhero suit for Genesis 2 in Carrara 8.5 pro
porthos62porthos62 Posts: 48
Hi. I am trying to use the SuperHero Suit for Genesis 2 in Carrara. when I try to render I get the result shown in the attached JPG. (the suit doens't show and I just get 'patches')
Searching the DAZ forums, there is an issue in DAZ Studio with this and is resolved by smoothing or apply a 'push modifier'
Any help in getting this working in Carrara 8.5 pro would be glady appreciated.
Thanks in advance.
388 x 423 - 17K
  • DiomedeDiomede Posts: 15,158
    There is a discussion of some issues with the supersuit in a thread on Genesis. Issues with Genesis 2 might be similar. See
    http://www.daz3d.com/forums/discussion/30233/
    In the thread, Bigh suggests saving the suit out of DS as a .duf file then using it in Carrara. You might try that. If it is primarily an issue with severe poke through, you might try making a morph for the figure that shrinks it slightly, or a morph for the suit that grows it slightly, or using the alpha channel to make the part of the figure covered by the suit invisible.
  • porthos62porthos62 Posts: 48
    Thanks for the info. I'll check out that thread.
