Moving preset directory
My preset directory is installed into the program directory and weights 14go.
I would like to move it to another drive to save room on my system disk.
I know there is a file to modify to point Carrara to the new location, but I can't remember it. Does anyone knows?
  • DUDUDUDU Posts: 1,945
    edited January 2020
    There is an icon on the top right of your browser/library: clic and "add a folder" (ajouter un dossier, en français).
    Post edited by DUDU on
    I think I remember a reference to what Philemo is talking about.  Either Misty or Stezza has a post about a text file that can be changed.
    Rather than move the whole presets folder, I merely created a new presets folder and moved some stuff to that, as per Dudu above.  If done this way, however, some of the subfolders are best added individually because you have to designate what kind of content is in the subfolder.  For example, the new leaf folder has to be designated for objects:leaves, while the plant folder has to be designated for objects:plants.
    See here.  https://www.daz3d.com/forums/discussion/comment/5273141/#Comment_5273141
    edited January 2020
    is in the roaming apps folders
    the path to preference files
    C:\Users\username\AppData\Roaming\DAZ 3D\Carrara 8.5
    preferences.txt
    Post edited by Mistara on
  • DartanbeckDartanbeck Posts: 21,639
    edited January 2020
    Thanks Misty. That said, it looks like we 'might' be able to change the default "My ____" folders to show up from a different drive on this line of the file Misty mentions above:
    disk "C:\\Users\\darta_000\\Documents\\DAZ 3D\\"
    and then change "C" to the drive in question, like
    disk "E:\\Users\\darta_000\\Documents\\DAZ 3D\\"
    for example
    Post edited by Dartanbeck on
  • StezzaStezza Posts: 8,159
    years ago I added a folder structure to my D:/ edited the Carrara preferences file in notepad
    find and replace the preset
    and replaced with this -
    ObjB {
    AFol "D:\\3DSoftware\\DAZ 3D\\My Presets\\My Items\\"
    preferences.txt
    Thank you Misty, it's exactly the answer I was looking for.
