Applying material makes my figure go transparent
Hi all
I'm very new to this, so this is probably just a beginner's failure, but heck I don't know how to solve it.
So I have this nice material pack which adds paint to my figure, but whenever I apply one of the available options, my figure goes haywire - as in transparent.
First pic shows my figure before applying the material, second pic shows the figure after applying one of the materials.
I have a feeling why this happens but I'm not able to solve it.
Any help would be much appreciated.
This by the way is the starter genesis 8 female figure and according to the material description it should be compatible with the paint material.
Would be happy if this can be solved, so thanks in advance.
1494 x 517 - 103K
1462 x 480 - 102K
I suspect it's to be applied to a Geometry Shell - try Create>New Geometry Shell, then select that and apply the preset.
Thanks a bunch! Not 100% there but this helped a lot :)
This is a slightly tricky product to figure out, no instructions, from what I worked out you apply the Geometry shell from the folder with the Attachements in it, the attachments are the geometry shells set up for use with the paints there are 5 layers availble, then apply the paints to the shell.
There are also presets that apply the shell and the paints for you, except for one of the set I have that just kicks up and error.
