A Shadowy Proposition
niccipbniccipb Posts: 483
So I like to tinker and experiment with things that can be done in Studio :P
Earlier today I was uninspired, board or maybe just feeling lazy, but I had a thought. :wow: :exclaim:
"can something that is not there render a shadow?" My first thought was no, but then, why not?
I started thinking and had an idea. So when I got home from work I set up a simple scene in Studio and tried my idea, and guess what, it worked. :bug:
It was to easy I thought, so I created a scene inspired by a magicians act. The result is the first render below.
In the second image I decided to have a little fun ala Peter Pan.
These are 100 % rendered in Studio using 3Delight with NO postwork.
Now I'm sure some of the veteran Studio gurus can figure out exactly how I did this in a heart beat, so I put it to all of you to see if you know what I did to get this effect.
Post your solutions, include a render if you like, start a discussion amongst yourselves, after all this is the Discussion forum. I would really be interested in how you would achieve this effect or if you can figure out how I did it.
I'll tell all sometime this weekend. Until then let's see what you've got. :coolsmirk:
800 x 800 - 112K
800 x 800 - 116K
  • bighbigh Posts: 8,147
    to easy
  • NeilV_1NeilV_1 Posts: 442
    edited July 2012
    I wont give it away but we have been able to do this for quite a while (I did this image in 2007 created in DS no post work)
    1200 x 1200 - 81K
    Post edited by NeilV_1 on
  • niccipbniccipb Posts: 483
    Oooh... I really like this image NeilV... yea I knew that those who have been doing this for far longer than I would know how right away...
    For me half the fun is in finding and figuring out how to do these sorts of things. This started with a thought and I worked it out... if I had seen your image, I would have sat myself down and toyed around until I got it.
    My hope is to maybe inspire a few others who haven't learned this simple trick to also play around and have some fun with it.
    Thanks for sharing... :)
    I, of course, don't use DS, but have done similar things in Bryce.
    Another thing I also like playing around with is reflections of things that aren't there, can do some real spooky effects with them as well.
  • adamr001adamr001 Posts: 1,322
    One of the more interesting things you can do in DS is negative lighting. Double click on a light's "Intensity" setting and remove the Use Limits checkbox, set the light to a negative intensity and see what happens. :)
    yep its lots of fun to play around with these things yourself and see what you are able to came up with.
  • Oom FooyatOom Fooyat Posts: 0
    edited July 2012
    There was a thread on the old forum on how to make a shader that don't generate a shadow and/or reflection. You could use the same setup to turn of visibility but keep the shadow too.
    The cylinder is one object with two materials.
    400 x 400 - 49K
    Post edited by Oom Fooyat on
  • ReDaveReDave Posts: 815
    Well, how did you do it? Fantom on Ubersurface?
  • ruekakaruekaka Posts: 346
    Would you provide your secrets, I'm really curious.
