DOF in Bryce
bombenleger58bombenleger58 Posts: 108
Where i find a Tutorial for DOF in Bryce?
thanks
  • HoroHoro Posts: 10,710
    I don't know, I'm afraid - but it's easy enough to use. Select an object where you want to have it sharp. In the Render Options, enable to Premium and Depth of Field. Then click on Set To Current Selection. This gives you the distance from the camera to the object. It is called "Focal Length" which is a misnomer. "Lens Radius" (another funny name for the f-stop) lets you adjust a wide or narrow DOF. The smaller you put that value (smallest is 0.001), the wider the range of focus. It does work like the f-stop. Smaller apperture greater range, larger apperture smaller range. You've got to experiment with this a bit. I hope this gets you going.
  • bombenleger58bombenleger58 Posts: 108
    Horo thanks for your fast Reply. I will play a little bit!
    Norbert
    Towards the end of this video. http://www.youtube.com/watch?v=8WTYURTvXkw&feature=player_embedded Taken from the list here, http://www.bryce-tutorials.info/bryce-tutorials.html looking under my name.
  • kiwi_ggkiwi_gg Posts: 198
    You might also want to look at this one too.
    /www.renderosity.com/mod/tutorial/index.php?browse&section_id=15&page=3
    Cheers
    GG
