Why Does Genesis GoTo Pieces?
When I load a genesis figure from some of my saved scenes it goes to pieces.
https://picasaweb.google.com/111541585734382779727/DAZStudioRenders#5763994001332996242
https://picasaweb.google.com/111541585734382779727/DAZStudioRenders#5763993989034193490
Seems to only happen with the recently saved scenes
  • larsmidnattlarsmidnatt Posts: 4,511
    Sorry can't help you. Surprisingly the thing I notice is the wardrobe malfunction!
  • adamr001adamr001 Posts: 1,322
    What version of DS4 are you running?
  • edited December 1969
    Version4.5 supposed to be pro but loads as standard, Keep getting an error message that says duplicate IDs were found
  • JaderailJaderail Posts: 0
    You will need to Update some of your older Genesis Morph sets by reseting them and all that, or I have seen a fix posted in one thread that will do it. I'm not sure which topic it's in, I hope somebody points you to it soon.
    Was the scene created in 4.5, or was it created in DS4.0 and saved as a .daz file?
    Loading as standard, not Pro, sounds as if you aren't entering the serial number correctly - Ds4.5 will run, in standard mode, without a serial.
    Richard, the daz files load correctly, it is just the ones created in 4.5 that malfunction.
    Perhaps I need to retry my serial number
    Thankyou all for responding
  • gabugabu Posts: 303
    edited July 2012
    I had the same problem with the genesis character being distorted as in the examples given by the OP.
    I had to switch back to 4.0 because of it.
    Does anyone know where the thread is with the fix that Jaderail mentioned?
    Post edited by gabu on
  • BejaymacBejaymac Posts: 1,889
    In 4.5 how are you saving your scenes, "File>>Save As>>Scene.." or "File>>Save As>>Deprecated>>Scene (.daz).."
    “File>>Save As>>Scene..”
  • Scott LivingstonScott Livingston Posts: 4,340
    I believe this is the thread: http://www.daz3d.com/forums/discussion/1900/
    As I recall, it has info on this problem as well as the duplicate ID thing (not sure if they are related).
    @Scott. I scanned that thread and can't find anything about the genesis distortion. Admittedly my eyes were glazing over.
    My problem was with RC1.
    I think I will wait till the final release before I try again as I need the plugins working anyway.
    The problem is still occurring, it only seems to be with the basic female and it doesn't seem to matter if she is wearing clothes or nude. It doesn't always happen just often enough to make me have to redo scenes every once in a while.
    I met same genesis body explosion in 4.5 rc2 as old saved . daz sceen.
    when I load so simple girl genesis jsut pozing ( shaped some morphs)
    scene in ds 4.5, the body were parted away.
    and I can not find precise way to avoid or correct it. and I could not find what cause the change giometry.
    as for me almost of my old daz.scene before I saved in 4.0.3 could not be reused.
    at that time , I thought this problem might happen when ds 4.5 CMS,can not find some handmade morphs for genesis
    which saved in genesis folda.( I lost or change or overwrite somewhat,,)
    Now I want to check it again in 4.5 rc but many of us can not use both of 4.0.3 ver and RC3 same time, in one pc.
    with one daz data folda.
    so if you can find the cause of exprosion, memorize here please.
    I feel it is important to find when the exprosion must happen.
    I knew some (not a few) men meet same problem about ds 4.5 (rc1 ,2,3) and mentioned here.
    Some of us should forgot or put off about RCver (which may have many new improvements)
    then truned to 4.0.3 because of the figure exprosion I think.
