global tween change?
![tami_7956c1f21d](https://secure.gravatar.com/avatar/e03543b1359a2445a5fcad1978d9b013?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fe03543b1359a2445a5fcad1978d9b013_100.png)
Is it possible to make a global change to all the tweens in an animation in Carrara? I can't seem to "select all" tweens, which would be the way to go, I'd think. I have too many tweens to select manually.
I know how to change the default tweener, but at this point, I have an animation already set up and I want to change all the tweens (to the same tweener) at this point.
Thanks in advance for help!
In this case, the best way that I know is to open all of your hierarchies in the sequencer and drag a selection around all of the tweeners at once. Right, there is no select all function for that.
