Weird error trying to apply Mat?
WsCGWsCG Posts: 391
edited February 2020 in Carrara Discussion
Hello everyone,
So, working on creating my very own pet dragon, and have an error popping up that I haven't been able to work out.
I'm trying to apply the Bump Mat to the DAZ Dragon 3, and keep getting an error popup. Happens regardless of whether I double-click on the MAT, or try to drag it to the figure. Everything else with the dragon has been working fine so far. Just the bump mat doesn't want to play along. I do have the dragon selected when I'm doing this.
Any tips/help is appreciated!
Thanks!
842 x 677 - 66K
Post edited by WsCG on
    prolly easiest to load bump map manually.
  • StezzaStezza Posts: 8,159
    as Daz3d won't update Carrara the easy duble click apply that is used in DS doesn't transfer most times now to Carrara..
    so as Mystiarra says you have to manually apply the textures to your model via Carrara's texture room, so knowing where the jpg or png or whatever are located on your PC is needed.. here is the cat used as an example..
    you will need to adjust most of the settings manually to get the best effect. wink
  • WsCGWsCG Posts: 391
    Ahhh  okay. That would explain it.
    Cool, thanks a bunch for the help, Mystiarra and Stezza.
    I'm full of questions today lol.
