Keyboard shortcuts gone from menu (Solved, yay!)
3dLux3dLux Posts: 1,231
edited March 2020 in New Users
[Keyboard shortcuts gone from menu] As in they are no longer there.  Prior to them disappearing I was working on an older scene and the shortcuts were function, specifically Ctrl+S, whhich I used a lot.  Then I opened a newer scene added elements but when I tried saving with Ctrl+S nothing happened.  It actually took me a bit to realize that the keyboard shortcuts were gone from the menu.  On another computer they're still there, though.
My main computer has D|S 4.12 while the backup has D|S 4.10.  Not sure if that's the cause though because Ctrl+S was working until 30 minutes ago, literally crying
Hoping someone can point me in the right direction for a solution sad
Post edited by 3dLux on
  • Richard HaseltineRichard Haseltine Posts: 102,721
    That usually means that the setting .dsx file has become corrupt or been overwritten, possibly as a result of a DS crash on exit or possibly due to security software or a system utility. You can restore the defaults by going to Window>Workspace>Customise and using the Import... button at the bottom to reload Actions; you can also just use Window>Worksapce>Select Layout to reload the whole thing. I would, if you customise your shortcuts or the nterface as a whole, use Window>Workspace>Save Layout to save the settings
  • 3dLux3dLux Posts: 1,231
    WooHoo!  Thanks muchly, Richard smiley yes  The Import Actions did the trick! heart  I had tried the Layout earlier with no results and I do save the Layout every so often angel
    Heading off to bed now as it's 7.00 am on my side of the world and I can finally sleep now laugh
