Vyusur Janna etc in Carrara
DiomedeDiomede Posts: 15,202
edited April 2020 in Carrara Discussion
Having problems with workflow to get Janna's brows to follow a custom morph for Janna's face.
1) Converted Janna to blended and saved as support asset
2) Converted brows to blended and saved as support asset
3) Used modeler to make a morph for blended Janna  (saved morph as asset and then saved morphed figure as support asset)
4) Loaded blended Janna with face morph in Carrara but morph dialed to 0
5) Loaded blended brows for Janna.  Used FIT TO on brows for Janna blended
6) Dialed Janna blended face morph to 1.  Brows did not follow a projected morph
Janna blended and brows blended default shape and fit to
Janna blended with custom face morph dialed to 1.  See outside halves of brows disappear.
1290 x 887 - 563K
1443 x 837 - 600K
793 x 705 - 285K
1341 x 970 - 617K
Post edited by Diomede on
«134
  • VyusurVyusur Posts: 2,235
    edited March 2020
    In order for your new morph to work with brows you can do the following steps.
    Fit the brows in DS, dial up your morph with brows on.
    Turn of Janna's visibility in scene pane.
    Export the brows to obj in base resolution.
    Load the new brows in empty scene, load your obj as a morph.
    Save your brow morph to the brows folder.
    Then you would be able to apply your morph to fit Janns's new form after fitting them in Carrara.
    BTW, nice witchy morph.
    Post edited by Vyusur on
    do the brows have the face rigging? mebbe pose em into position?
    woe, they took down the Janna walk cycle demo video.  instead its some stoopid dforce thing.
    was trying to figure out if it was an animates converted to janna?  was it custom walk cycle?
    edited March 2020
    I'm affraid, I didn't understand your comment about video. I used the walk cycle for Genesis 8 Female. It's completely compatible with Janna:
    edited March 2020
    Thank you for the animates info.  couldnt remember if was the hand on hip walk
    thought i remembered the product page for Janna with a walk cycle clip on the page.  the video clip on Janna product page is now a dforce ad.
    or is just what i seeing in my browser
    Post edited by Mistara on
  • DiomedeDiomede Posts: 15,202
    Veronika - thanks.  I wonder if the morph I created wasn't saved to the correct data location by morph loader.  In any case, should be able to address.  And thanks for the kind comment about the witch face.  I should note that the brow follows my facial morph in Studio, but not Carrara.  Maybe I needed to save the blended fiber mesh brows as a wearable preset instead of new support asset?
    Misty - yes, Janna has some facial bones, including for the brows.  Have to fix my morph load before I can test the facial bones, though.
    Ted, of course, the brows have to be blended version with morphs. It's up to you to save morph separately or the whole figure with morph. Honestly I use scene subset save option pretty rare. Usually I save the figure as support asset.
    would love retro scifi costumes for Janna.  Jetsons-ish or flintstone costume for Janna
    a bodysuit?
    enlightenedheart
    Hi Vyusur would it be al right if i made presets for Janna, Leon, and Teena
    not that anyone needs it.  would just be a convenience.
    any plans to release a merchant resource skin?
    Hi! This kind of products would be rejected because of low commercial value. I don't have enough health and energy for products that don't have commercial value. I'm affraid, I can't help you with merchant skin. But you can make Carrara presets without any skin at all. As for sci-fi bodysuit, I'll put it on my schedule.
    what about this product  https://www.daz3d.com/genesis-3-and-8-females-texture-merchant-resource-pale-skin
    is this strictly for genesis eses ?  am i allowed to kitbash it to Janna?
    thankssmiley
    You are welcome to kitbash any of my merchant skin recourses as you like.smiley
    edited April 2020
    Vlad in Carrara
    with the weight of the world on his shoulders.
    Convert to blended weight and did some minimal shader tweaks and used default render settings.
    480 x 640 - 15K
    Ha-ha-ha! Nice.
    If someone interested in, I've just uploaded G8 clones for Leon and Teena into freestuff section on Rendo. As I mentioned before, these are not perfect for footwear.
    interested!  thank you
    You are very welcome!
    Thank you!
    Diomede said:
    Thank you!
    You are welcome, Ted!
    dohhh, i looked under carrara free stuff  lol  blush
    i been wanting to put the v4 centurion get up on Janna
    i promoted my Janna actor to captain of the dragon guard. smiley
    which meant demoting TY2.  i feel bad, but Terai Yuki not sulking.  lol
  • Bunyip02Bunyip02 Posts: 8,732
    Thanks !!!
  • StezzaStezza Posts: 8,148
    sweet... would be awesome if there was a G or G2 one as well... just thinking outside the box wink
    For footwear I found saving as a subset ( in DS ) then loading into Carrara has worked so far. cool
    edited April 2020
    Leon onboard a Space Station
    1600 x 2068 - 5M
    Post edited by Bunyip02 on
    Nice! Such a huge boots!
    edited April 2020
    Thanks !!
    Boots were extra large with the set it came with.
    Another Leon.
    1600 x 1200 - 3M
    Cool! Why don't you use some fill lighting? You can use mine if you want.
    zip
    zip
    Directional_Light.zip
    4K
    zip
    zip
    Plane_light.zip
    4K
    Thanks, had a fill light (bulb) and a key light (Distant) in front, along with 2 rim lights (bulbs) at the back, in retrospect should have used a spot light on Leon to brighten him up a bit.
    Have not used a plane light in Carrara before, will have to give it a go !
    If someone interested in, Genesis 8 clone for Janna is available on Rendo.
    Thanks !!!
