AniMate2 display
Hi, i have an issue, well, dont know if is an issue itself but, i had to format my pc, so i installed everything again... short story, the thing is that when i play an animation in the timeline on AniMate2 it low the mesh resolution of the scene, from High Mesh Resolution to Base Resolution. There has to be a way to lock it on high res as i had it before? maybe they changed that on a update  but i want to keep them on high resolution. Thanks
  • Richard HaseltineRichard Haseltine Posts: 102,721
    I'm not quite sure what you mean - is this in renders or in previwe? If so check the Draw Settings pane, one of the options will delay SubD (and I think delayed is its default state).
  • edgjakeedgjake Posts: 3
    That's it, thanks you bro ♥
