v9.0 -- mcjBuilderA - script to build anything in Daz Studio - updated sept. 16 2017
mCasualmCasual Posts: 4,607
edited September 2017 in Freebies
https://sites.google.com/site/mcasualsdazscripts3/mcjbuildera
while building the mcjCastle
i needed sanely UV-textured handrails that could be re-generated quickly
so i wrote a script
1280 x 720 - 118K
200 x 850 - 29K
800 x 500 - 152K
1920 x 1080 - 598K
1200 x 1200 - 106K
Post edited by mCasual on
«13456711
  • Miss BMiss B Posts: 3,071
    Oh, I'm going to be watching this thread with interest. :coolsmile:
  • mCasualmCasual Posts: 4,607
    edited March 2014
    to create this frame i selected a pre-defined path ( an obj file )
    and a square extrusion profile and pressed a button
    you'll be able to define your own paths and extrusion profiles if you can create a polygon using Blender or most 3d modeling software
    or using mchLathe/mcjSuperLathe
    but the script will also include a good collection of pre-defined profiles and a few paths ( for instance the square path for picture frames )
    1920 x 1080 - 266K
    1920 x 1080 - 2M
    apparently the little gap issue is not fixed
    (better than in the previous images though )
    1920 x 1080 - 614K
  • StratDragonStratDragon Posts: 3,249
    edited March 2014
    Supreme digity! Walls with baseboard and moldings make the difference between a room and an unconvincing box trying to be a room. this is an invaluable script, I can't wait. Thanks again!
    Post edited by StratDragon on
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,239
    Looking very interesting!
    This means I have to abandon my tried and true method of making mouldings...get the profile, in SVG format, take it into Blender...convert to mesh object...extrude...spend a bunch of time fiddling with UV mapping...give up and just 'paint' it...then bring into DS and scale it...give a 'semi-gloss' enamel paint job and call it done...
    edited March 2014
    an accidental animation
    320 x 180 - 777K
  • IvyIvy Posts: 7,165
    that script looks very cool , and it will be very useful. :)
    edited March 2014
    maybe her full name could be Amy Welder
    1600 x 1200 - 2M
    600 x 1000 - 96K
  • RAMWolffRAMWolff Posts: 10,222
    Awesome. Looking forward to this script! YAY!
    if i don't digress ,,,,,,,,,
    it's a done deal the moulding builder script will be posted this weekend
    example 1 of a diversion,
    the sleeve-with bodycon
    example 2 of a diversion,
    the flat-bottom environment sphere ( you take the uberEnvironment light sphere, ,
    1920 x 1080 - 364K
    edited March 2014
    How it works
    the script creates a node named "the transporter"
    it loads and positions nodes according to the shape of the selected molding
    in this case a handrail molding
    this is called the profile curve
    the profile nodes are then parented to the transporter node
    then following the instructions listen in the text box
    the transporter gets moved and rotated along the extrusion path
    those movements are keyframed
    once that's completed
    the positions of the profile curve nodes are used to create the 3d object, in this case a rectangular frame
    1920 x 917 - 268K
    edited March 2014
    good news one will be able to create frames made up of only 4 segments
    DS render
    1 area light
    very simple texture
    see attached
    FuzzyWuzzy shader for the ground ( by Marianne - http://www.sharecg.com/v/36638/View/6/Texture/Fuzzy-Wuzzy-Fur-Shader-Daz|Studio )
    defining the extrusion path is done wit texts like this
    type mcjBuilder
    source square.obj
    vrsn 2014.03.26
    Hardturn 90
    Move 2
    Hardturn 90
    Move 2
    Hardturn 90
    Move 2
    Hardturn 90
    or you will be able to supply it in the form if an obj file
    1024 x 384 - 35K
    1280 x 720 - 866K
    DOOOOD.. that looks awesome!
    edited March 2014
    slightly more complicated extrusion path "recipe" for round corners
    figure 2 -- the UVs need to be sorted out though
    1280 x 720 - 343K
    1280 x 720 - 108K
  • none01ohonenone01ohone Posts: 862
    edited March 2014
    This script is the dogs ball..k's. Really looking forward to making some picture frames, railings, coving, window and door frames, skirting moulding's, kitchen work surfaces etc. Could you make a door with this script, ie, fill in the centre ? Just wondering if I could make a Georgian paneled door by putting together 4 or more scripts.
    Post edited by none01ohone on
    edited March 2014
    since i want to finish it this weekend, i don't know if i'll include path-caps and end caps, mcjSuperLathe could do them though, i called them cutouts
    the path files used by mcjBuilderA will probably be fully compatible with mcjSuperlathe and the less complicated mcjLathe
    http://www.daz3d.com/forums/discussion/1785/
    https://sites.google.com/site/mcasualsdazscripts/mcjlathe
    also i have a paneled door prop on my web site and a morphing wall prop
    https://sites.google.com/site/mcasualsdazscripts2/mcjdoor
    https://sites.google.com/site/mcasualsdazscripts2/mcjhole-mcjbox-props
    600 x 490 - 88K
    600 x 600 - 50K
    600 x 600 - 59K
    edited March 2014
    working on the script tonight!
    1280 x 800 - 55K
    1280 x 720 - 241K
    1280 x 720 - 428K
    edited March 2014
    oh my Bob ! i think i got it ( meaning the UV map is now behaving ! )
    the UV layout method here
    is optimized for picture frames
    each segment of the frame ( most often 4 segments ) gets unwrapped
    the continuity of the texture is enforced along the path ( bird eye view )
    it's a very chopped up UV map but it prevents stretching and distortions
    there will be a second method, better suited for frames with round corners ( like the one shown here )
    with that method, the consecutive short tube's uv coordinate will be welded together
    those introduces small distortions but removes the breaks in the texture
    this will be used for staircase handrail curves and wood-grain textures
    1920 x 1080 - 427K
    1920 x 1080 - 493K
    nice road huh?
    ( if you know what the Bobverse is, texturing its roads was quite a task ... and you didnt see the next Bobverse ! )
    more complex path, there's some imprecision to fix .... i'll work on it later today
    i may publish a beta version since it can already do things like 4-sided frames without problems
    which means i will write a first "manual" (page )
    1920 x 1080 - 202K
    That UV work is outstanding.
    This is really coming along well. :coolsmile:
    checking the uvs ( the ones that sacrifice continuity for non-distortion )
    910 x 910 - 178K
    The UVs look really good. :coolsmile:
    trying to publish a beta version that can at least do frames
    1920 x 1080 - 320K
    That would be great, as then I'd be able to "frame" some of my renders and hang them on the walls of the castle. :coolsmirk:
    edited March 2014
    mildly bad but expected news is that the pre-beta version is not ready
    the good news is that it will include creation of "caps" for simple ( convex ) framed areas
    like , say, the photo or painting that goes in a frame
    like say the fake hubcap that goes in a tire
    like, say the surface of a table with nice moldings
    maybe also ... gears !!!!!
    ( reason for the delay, i added code to convert scripted extrusion paths into polygons that can be previewed and saved in obj format )
    1920 x 1080 - 469K
    Thanks for the cherry on top of the cake. ;)
    making humanly-texturizable tires and a simple lid/cap/hubcap
    1413 x 788 - 148K
    I was just going to thank him for the icing on the cake. By the time he finishes this up, there will probably be more goodness that will deserve the cherry. :coolsmirk:
