Center the manipulator (gizmo?)
Hello. Often the universal manipulator is far from the object, making it difficult to handle. Is it possible to move this manipulator on the object?
  • Richard HaseltineRichard Haseltine Posts: 102,720
    Is this for an object or a figure? I suspect it's the latter, in which case the solution is to make sure that you perform any major moves using the figure node and use the root bone (the hip on humans) only for placing the figure in space (on the floor, placed to shake hands with a second figure, etc.). If that is the issue you can transfer the translations from the root bone to the figure node to bring them back together.
  • Thanks for your answer. Actually no, it's more for objects
    Plain objects without any bones? Taht's odd, are they importing off-centre (assuming they are your own models)?
