Clothing from Blender to DAZ
in New Users
Hi,
I've modelled a hoddie that I want to export from Blender to DAZ, but I've no idea how and I can't get it to work. Are there any tutorials or guides on how to accomplish this?
Thanks in advance!
Export as OBJ, import into DS (making sure it lines up with the zeroed base figure as imported), Edit>Figure>Transfer Utility setting the Source as the base figure and the trget as the OBJ should get you started. You coudl also try using dForce - Edit>Figure>Geometry>Add dForce Modifier: Dynamic Surface - and run a simulation from the zero pose.
