Problem with Daz visualization
hi, this is the first time i use daz, and i have a problem that you can see in the image. it happens as soon as I insert a new element in the scene, and each time I have to save reload. What do you think it can depend on? (when I render, the image comes out correct even if it is displayed in this way)
1899 x 979 - 2M
Post edited by Chohole on
Does your computer have an Intel GPU on the CPU and a stand-alone GPU by AMD or nVidia? If so make sure that DS is using the latter for display - right-click on the desktop and select the nVidia or Catalyst Control Panel to do so. It may also be a matter of needing to update the driver for your video chip.
Saw an image similar to that someplace on the 'Net and the solution given was to update the drivers.
Yes, actually DAZ used the Intel GPU and not the Nvidia, I have changed the settings and for now I have done a test. It seems to run well.
