dson importer problem
marsoudamarsouda Posts: 9
I've downloaded dson for poser 9 with install manager and when I want to install it there is an error message :
Install Manager cannot find a required path. The installer for "DSON Importer for Poser (Win 64-bit)" requires that the installed path for "Poser Pro 2014, Pro 2012 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
What can I do please ?
I've found a poser 2012 folder in C program and found the dson folder here what to do ?
thank you very much
  • frank0314frank0314 Posts: 14,313
    Are you installing it with DIM? If so you need to add your path to your Poser directory in the Applications tab in DIM
  • Richard HaseltineRichard Haseltine Posts: 102,745
    Click the gear icon at top-right of the Install Manager interface to open preferences, then go to the Applications tab. There click the + to add an application, set the options for your version of Poser (name, version, and bit-depth) then click the ... button to select the folder it lives in. The screenshot shows me adding Photoshop, but the steps are the same.
    602 x 555 - 72K
  • marsoudamarsouda Posts: 9
    Thank you very much for this ! It's ok now.
