Semiramis Poser for Genesis 2 Female Vic 4 morph
OnieOnie Posts: 20
edited April 2014 in New Users
Hi,
How do i install this product? I have the files but it does not load.
It is not in Pose format too.
Thanks for helping.
1912 x 972 - 793K
Post edited by Onie on
  • frank0314frank0314 Posts: 14,313
    How do you have a runtime within a runtime? Are you installing files manually or with DIM?
  • vwranglervwrangler Posts: 4,902
    Leaving aside the nested Runtime structure Frank mentions, the actual user files to work with Semiramis should be in \Runtime\Libraries\Pose\SAV Semiramis (or possibly \Runtime\Runtime\Libraries\Pose\SAV Semiramis given the structure you seem to have -- and that desperately needs to be fixed, by the by; you need to merge the two runtimes and have Studio scan known directories for files to figure out what you did).
    Also, SAV Semiramis is for Victoria 4 only, not Genesis 2 Female. Her files will only appear in the Runtime\Libraries section for Poser, not in the DAZ Studio files. You need to have Victoria 4, and V4 Morphs++ to use her properly.
  • OnieOnie Posts: 20
    Hi Frank, i use DIM :-) no idea how it becomes like that.
    Hi Vwrangler, i have, http://www.daz3d.com/victoria-4-for-genesis-2-female
    i will try it now
    Thanks guys!
    edited April 2014
    Victoria 4 is a separate character that has nothing to do with Genesis 2 Female.
    You'd need these to use Semiramis properly:
    http://www.daz3d.com/victoria-4-2-base is required
    http://www.daz3d.com/victoria-4-2-morphs is optional for the body
    http://www.daz3d.com/v4-elite-body-shapes is optional for the body
    The only way to get Semiramis onto Genesis 2 Female is by using GenX2 with the Genesis2 addon and transfer it.
    http://www.daz3d.com/genesis-generation-x2
    http://www.daz3d.com/genx2-addon-for-genesis-2
    You'd still need the Victoria 4 figure + optional morph packages even if using GenX2.
    Post edited by Lissa_xyz on
    Hi Vaskania, now i can see, that is the problem :-)
    thanks everyone!
