I can't get my hair in the Iray Render window
in New Users
Hi,
I need your help. I can't get my hair in the Iray Render window (see picture in the attachment). I would be very happy if you helped me.
Thanks a lot
Reza from Berlin
2942 x 2718 - 2M
Which version of DS are you using
Hi,
I use DS 4.12.0.86.Pro Edition (64-bit) • Mac Pro, MacOS High Sierra.
Thank you
It's a dForce hair, so firstly make sure you're not in the Geometry Editor tool, as dForce hair won't render if you are. If that's not the problem, look at the hair (not the cap if there is one) and in the parameters make sure viewport and render line tessellations are set to 3.
Hi Redz,
Thank you very much, it worked and now I can continue. By the way, I looked at your gallery, great.
Reza from Berlin
Glad you got it sorted Reza.
Redz (from Dublin)
Thank you very much
Reza
