How to install v4.2 in Poser on OSX Mavericks
BlazmethBlazmeth Posts: 36
edited December 1969 in Poser Discussion
I just bought it and spent the last hour figuring out how to install it. Total newbie here so it would be great if the instruction could be clear enough that I can't mess it up!
What I have tried: zip installer from Poser 10 => fail
Thanks
    Can you explain in more detail what you tried? If you are installing manually, make sure you did not put the folder named Content inside your actual content folder -- the Runtime folder inside the zip needs to be merged with your actual Runtime folder. You will also need to manually run the "Runtime:Libraries:!DAZ:DzCreateExPFiles-V4.COMMAND" file.
  • BlazmethBlazmeth Posts: 36
    Sorry, I think I was just too tired because I just copied the files and ran the script and is seems to work. I can add Victoria to my scene. I can't confirm if the morphs are working because... well... I dont know how these things are supposed to work yet :-S
