What's wrong with my Misu's eye?
Leo ChenLeo Chen Posts: 697
After adding "V4 Elite Texture: Lana", Misu's eye balls have something wrong.
How come?
1810 x 722 - 1M
  • frank0314frank0314 Posts: 14,313
    What are you seeing wrong? I must be overlooking it.
  • ZarconDeeGrissomZarconDeeGrissom Posts: 5,412
    I noticed something similar in the past. Either the texture didn't go to the edge of the eyelid, or the eye somehow moved back a bit from the eyelid. I don't know how to fix that.
    I assumed that skin texture was the wrong one for the figure (G1/G2), ditched the whole mess, and tried another one from scratch.
  • JaderailJaderail Posts: 0
    The elite textures All show the TEAR of the lower Eye Lid as a semi translucent item, that is just the TEAR material zone with high rez textures applied to it. The Smudge looking thing at the bottom of the cornea is the tear mat zone.
  • Leo ChenLeo Chen Posts: 697
    Just as Jaderail and zarcondeegrissom said.
    I do not know how to fix it neither except using another skin texture.
    Thank you for sharing your knowledge, Jaderail.
    BTW, is there any way to fix the problem?
    It's not intended to be a 'problem'. It's there for realism, since your eyes naturally produce tears to keep your eyeballs clean and clear. You can hide it by changing the tear opacity to zero and ensuring there's no refraction or reflection settings (set them both to zero), but generally speaking it's rarely noticeable enough to be an issue even with the most extreme close ups on the face.
    Thank you, HeraldOfFire.
    Opps, sorry. I thought my saying it was a material zone (Surface Tab, material section, Tear) that the user would understand that it could be adjusted in the Surfaces Tab. Next Time I will try to remember to include more information on how to correct the issue and not just explain what it is.
    Thank you,Jaderail.
    You are very helpful.
