Problem with the selection.
Hi Daz friends,
I have a problem with the selection. I did something with Geometry editor a few days ago and since then I can no longer select the figure with one click (image).
Sorry about my poorest english language, google helped me.
Thanks a lot
REZA from Berlin
3608 x 2708 - 2M
    Check the Tool Settings pane - I suspect, if I am following, that you have Node Only as the seelction mode rather than Root then Node or Root Only.
  • Check the Tool Settings pane - I suspect, if I am following, that you have Node Only as the seelction mode rather than Root then Node or Root Only.
    Thanks Haseltine. I am very happy. Thanks again
    Reza
