Problems with Oso3D Pixie Dragon
Rhian-SkybladeRhian-Skyblade Posts: 223
edited April 2020 in Carrara Discussion
Hi everyone,
I got myself the Oso3D Pixie Dragon. Though, I bumped into some issues.
It doesn't load properly. All that actually loads is the Daz Dragon 3. The WingFeathers only load as some skeletal whatever, and using some of the textures/matierals ends up with an error message "Error: node name://%40selection/Dragon: not found".
Any ideas or tips & tricks how to get the pixie dragon to work with Carrara 8.5 Pro? Is there a workaround? Or is this now the newer type of content that does simply not work in Carrara like Genesis 3?
Since it's close to midnight here, I might not answering for a couple of hours. (Living in Europe :))
1916 x 1041 - 308K
Post edited by Rhian-Skyblade on
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,352
    edited April 2020
    I don't own it but you probably need to load it on to dragon 3
    if it's geografts the UVmapping will be broken in Carrara too so a second geograft needs to be fitted to the first one with the first one hidden
    doing a scene subset in that Carrara plugin DAZ studio and loading that is a good idea
    also make sure any geografts or conformed not parented to the dragon
    DAZ studio does that because they use hierarchical poses so it's the default
    but Carrara hates it
    edited April 2020
    yes your wings feathers are parented to the dragon
    drag them off
  • Thank you so much. Can't wait to try this after work :)
  • Update.
    So I experimented a bit with Carrara and Daz Studio and I am really saddened that I can't get it to work.
    The feathers do not show in Carrara. So my guess is, that carrara cannot display these feathers. I guess that it is something only DazStudio can display... I tried export the scene including the dragon as a poser format, but that did not work at all - it simply did not create the file.
    In Carrara, after importing the duf file, all you see is just the blank skeleton. It also can't be conformed to the Daz Dragon 3 :( it throws an error or crashes Carrara.
    ​Is there a way to convert those feathers and make them attuneable? (I really hate using Daz Studio, it simply can't do 90 % of the things I need - and the UI and Navigation is a clunky nightmare compared to Carrara)
    1925 x 1047 - 266K
    1919 x 1041 - 267K
    1918 x 1051 - 240K
    at least others know not to buy it for Carrara and if bought in under 30 days you can return it.
    yeah feathers probably use DAZ studio features and geografts are a known issue
    I am no help as don't own it
  • at least others know not to buy it for Carrara and if bought in under 30 days you can return it.
    You already helped me to verify that this is not going to work. I will look into returning it. Thank you so much :)
