Save D-Form Options DS4.6 "affect ALL items fit to the figure", Broken?
I gave the D-Form tutorial by 'RKane_1' a shot, and I think I followed the steps ok, till I got to step 19, of his first part of the multi-post tutorial.
http://www.daz3d.com/forums/discussion/6484/
It is a generic tummy morph, so it needs the "Also affect ALL items fit to the figure" checked in the save D-Form Options, thing is, there is no check box by that name that I can find.
I'm using Daz Studio 4.6, and I think he was on Daz Studio 4.0.
Thanks 'ben98120000', the setting dose exist, however it appears to not work at all.
1287 x 695 - 103K
1119 x 532 - 125K
Post edited by ZarconDeeGrissom on
File - Save As - Deprecated - D-Form Preset (.ds*)...
To add, its for saving D-Form presets (older version), which is different thing than saving (spawned) morphs.
Thanks for the tip, there is that check-box. That saved the D-form/morph in the Magnets folder instead of the other one, and when I called that back up it still poked threw.
Either that swimsuit is not compatible with d-form in that way, or I still missed something.
I made some screen-caps of the Studio 4.6 menus and options thing for this, I'll post them when I figure that tidbit out, later on. I have an ARES meeting I must go to, chat later y'all.
"ARES" that was a tad bit vague, Amateur Radio Emergency Service.
Edit > Preferences > Scene
Put a "tick" in the "auto-magnetize" option, then hit "apply" then "accept" to save the setting.
Thanks Bejaymac, I checked that last night before systematically trying every check-box I could find related to D-Forms and Morph settings.
It has been a long night of nothing working with this. Either the saved Morph assets do nothing when called up, or the slider dose nothing to the clothes.
I'm beginning to suspect that none of the morph packages do anything to that aria of the waist without drastic non-correctable distortions elsewhere, because it is somehow not allowed by daz studio.
At this point, I am tired, and need to walk away from this out right failure. I will simply hope that there is a morph somewhere that I have not located and purchased that fixes this, because D-Form in Daz Studio 4.6 is broken. It's the only explanation that I can think of.
I just looked threw the store, and I have all the ones they list for G2F.
Genesis 2 Female Mixed Morph Resource Kit
Genesis 2 Female Body Morph Resource Kit 1
Genesis 2 Female(s) Morphs Bundle
I just want to take the sharp edge off of the impossibly thin 'Barbie tummy'.
The reason it is under Save As - Deprecated is it is meant more for Generation 4 and earlier figures. Genesis Classic and Genesis 2 clothing will auto follow the figures morphs most of the time so if you convert the D-Form into a morph for G2F and set it to auto follow you don't need it in the clothing.
I'm fairly sure that that "Auto Follow" in the slider "Parameter Settings" is for making it follow other sliders. It did nothing last night when I ticked it and clicked apply.
For the sake of giving it a shot, I went threw ALL the steps again, And screen-caped the steps. So If I understand Y'all correct, this really should work, unlike the results I got?
