Hi
in New Users
Good morning all,
I've been using Daz for a while, but here I have a problem with certain poses. The upper body is not positioned correctly and only with the Z fitness and Z natural Breast set. Because with all the other set of poses that I have, I have no problem.
Thanks
Hi there!
You may want to check that you are applying the full body version of the pose and not the upper or lower body. In this set Z included the full body, upper body and lower body as separate poses so the image you attached looks like one of the lower body poses being applied. Same with the Natural Breasts poses as well there are multiple versions of the base poses for different body parts and combinations of body parts.
Hope this helps!
Elli
Please put the Viewport in Smoth Shaded mode if you need to take a screen shot of a nude figure.
