they won't turn with the rest of the stuff under the pivot with the spin modifier
you need to watch the video to see what I mean
I tried different constraints
strange - can you try with a target helper as an intermediate object? I vaguely recall having something like this happen to me quite a while back - don't remember the solution.
I am guessing it is something with the FBX import
it was 3ds but I changed it to FBX in iClone 3DXchange as Carrara 3ds import is rather crappy
change rotations to angles ?
by default rotation, they won't rotate 360
I can manually rotate them separately and I am using a spin modifier on the group so they do
your tyres do turn?
i'm confused
while it's a prop maybe it acquired some rigging?
no luck, tried groupimg
removing from tree, parenting to a target helper, angles as well as quarternium
can manually rotate it with arrows but it just won't move on a modifier
