XYZ axis problem
in New Users
Hi DAZ friends,
this is my 3rd try, maybe someone will help me. How can I place the XYZ axis in the middle of the ring (Image)?
Thanks a lot.
Reza from Berlin
2258 x 860 - 67K
Is that a figure a node with children) or a prop (a single node)
Hi,
I often have the problem that when I export a file from Cinema 4D as an obj format in DAZ 3D, the axes are always shifted in DAZ. If you could generally tell me how to center the axes, that would be very helpful. I deleted the old file, it was too much work to do. I attached the other file (image)
I thank you in advance.
Thanks a lot
