Mesh Grabber (Where is it?)
Purchased Mesh Grabber. Can't find it anywhere. Not in my install manager and it doesn't download manually. Any guidance would be appreciated. Thanks in advance!!
J
Try hitting alt+shift+E that activates the tool. Or it can be found in the tool settings panel, under the active tool dropdown menu
Do you have your download filters set to show software, Windows architecture (32- or 64-bit), and plugins? DIM Advanced Settings -> Downloads.
Same issue here, and it's 2024. Sent a ticket to Daz.
- First, check in DIM, Advance Settings - Applications, the path of DS application needs to be correctly configured.
- Install Mesh Grabber in DIM. After intallation, go to Installed tab, locate Mesh Grabber, right mouse click menu - Show Installed Files... make sure they're correctly installed in plugin sub-folder in the root directory of DS application.
- Close and re-launch DS, check in Help - About Installed Plugins... Mesh Grabber plugins should be there.
- Mesh Grabber is under menu : Tools - Mesh Grabber, just press Alt + Shift + E to activate it.
Just so I know the right path is chosen. I got the Mesh Grabber bundle yesterday, there were 2 downloads that were exe's and on the rotations part no download, tho someone on my thread explained it can only be downloaded and installed thru DIM.
Should I ignore the exe's Idownloaded and just install all 3 parts through DIM? Also what is the correct path, as I have Daz installed on my main C Drive?
Yup, ignore EXE files but just download and install three IM packages in DIM. After installation, three DLL plug-in files locate in C:\Program Files\DAZ 3D\DAZStudio4\plugins, if you installed DS with the default application path.. as well as Public Build path.
When I installed Daz I didn't change anything and let it install to the proper default place, I do the same with anything in DIM, but will double check to make sure the dll's are in the right place according to your image.
Ok opened DIM, updated it and there are no Mesh Grabber installs in the list. Does this mean I need to send a ticket?, so annoying.
Odd... what's your DS version ? A simple way to install - extract the DLL files from IM packages to the plugins folder I showed above.Then relaunch DS.
Pls send a ticket at the same time...
I have Daz ver 4.21
Are you saying to open the exe's I downloaded (only 2 cause the rotation one had no download option), I assume to some folder on the desktop and take the dll's out of there and put them in the plugins folder?
This would be so much easier if they just had all 3 as zip folders to download with intructions on where to put the files.
They wanted to sell the products separately...![devil devil](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/devil_smile.png)
Go to your Package Archive folder, locate 3 IM packages, extract DLL file one by one...
Problem solved, it finally showed up in DIM, I installed, double checked to make sure the dll's were in the right place, opened Daz, tool showed and and tested to make sure it's working.
Thanks for your help Crosswind.
Great ! My pleasure.![smiley smiley](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/regular_smile.png)
