Morphing Fantasy Dress for Genesis 2 Female(s)
rumpotrumpot Posts: 96
Is there a way to fix the breast poke out with this item [Morphing Fantasy Dress for Genesis 2 Female(s)]? I am using Ambie from V6Pro and I get this:
Regards
Edited to place info from title in the body of the post
619 x 145 - 120K
  • Richard HaseltineRichard Haseltine Posts: 100,839
    Does the dress already have a Smoothing Modifier applied (it will appear in the groups down the left hand column of the Parameters pane if so)?
  • rumpotrumpot Posts: 96
    I do not believe so, is this what you were asking?
    357 x 366 - 25K
    edited May 2014
    I enabled it and it seems to be working, what would you suggest for the Iterations? 2 seems to work.
    Regards
    814 x 303 - 355K
    Post edited by rumpot on
    Keep it as low as you can, since it recalculates every time you change the figure's pose or morphs so you don't want the overhead to be greater than needed.
