Genesis 2 block form
bakaribakari Posts: 0
my genesis works just fine but if I try to do anything with genesis 2 female or male they come out in block form and won't render any clue how to fix this?
    How and where did you install the 3 Starter Essentials packs?
  • ElliandraElliandra Posts: 586
    Also are you getting any error messages popping up when you try to load them? Usually the "Grey Block" issue is from DS not finding all the data folder information it needs.
    Elli
  • KoshVKoshV Posts: 1
    I am having the same problem, the program cant find the file Genesis2Female.dsf
    in... /data/DAZ 3D/Genesis 2/Female
    The file is located in Users/public/Public Documents/My DAZ 3D Library/data/DAZ 3D/Genesis 2/Female
    I used the Install manager to install everything. First with default settings then with custom settings. Still does the same thing.
    So in order to get it to work I had to add
    C:\Users\Public\Documents\My DAZ 3D Library
    to Preferences > Content Library
    under Content Directory Manager Button. > Current Directories>DAZ Studio Formats
    Basically you open the window after you click on the button, then click on the arrow beside Current Directories, then click on the arrow for DAZ Studio Formats... then on the left under Directory click the Add button and type in the correct path to where the file is located.
    I dont know why the application installs to a location that it is not set to read at defaults. It was originally looking into my user account not the public folder. Maybe its an old preference from a previous version.
  • JaderailJaderail Posts: 0
    For Default installs your Paths in DAZ Studio should look like this for everything to work properly...
    429 x 467 - 62K
    edited May 2014
    That's exactly it -- a clean install of DS has both paths, but if DS was installed previously it keeps whatever the previous settings were.
    Post edited by fixmypcmike on
