Dragonfly AMU won't install
nightwolf1982nightwolf1982 Posts: 1,160
I just bought the Dragonfly AMU set, and it won't install through the DIM. I keeps saying that I need to define a path for Carrara, from 8.5 back to 6. Problem is I don't have Carrara, any version.
Any way around this?
  • nightwolf1982nightwolf1982 Posts: 1,160
    never mind, just looked at the DIM file, it's strictly for Carrara
    It's not exclusively for Carrara, it contains Poser and Carrara textures, but it is a texture set and requires the prior purchase of other products, the V4 body suit and the V4 body suit expansion.
    If you bought it within the last 30 days then you can request a refund by filing a support ticket to Sales dept.
    I meant the DIM file, is set up only for Cararra. The files in it are Carrara presets, there are no poser files.
    Can you file a ticket about that please
