room corner prop - walls with crowns and baseboards
mCasualmCasual Posts: 4,607
edited May 2014 in Freebies
========> https://sites.google.com/site/mcasualsdazscripts4/mcjcornerroom
a starting point for a render !
less boring then a simple room corner
The construction is modular so moving the ceiling up is easy
960 x 720 - 458K
1000 x 625 - 141K
1000 x 625 - 128K
Post edited by mCasual on
    Thank you, just grabbed it.
    Will have a play later :)
  • mCasualmCasual Posts: 4,607
    note : the chandelier is a separate free prop posted recently at https://sites.google.com/site/mcasualsdazscripts3/mcjlustre
    1920 x 1080 - 967K
  • edited December 1969
    Beautiful corner prop. Thanks!
  • robkelkrobkelk Posts: 3,259
    One can always use another place to pose one's figures. Thanks!
  • Miss BMiss B Posts: 3,071
    Oh this is very kewl. Thank you sir. :coolsmile:
    edited May 2014
    - update - poser - - update - poser - - update - poser - - update - poser - - update - poser -
    the new version will let Poser ( tested in Poser9 ) users to select and move the wall crowns, move the ceiling up and down and stretch the walls taller
    technically speaking
    for some reason, the prop file only had one "addActor" statement in the "doc" section
    so using wordpad i added the floor ceiling walls and crown props
    figure 2 "Pond AO" lighting , notice the bump map which carved bricks in the walls
    figure3 - dont worry the ceiling didnt get lower
    1055 x 698 - 523K
    1055 x 698 - 789K
    1074 x 752 - 107K
  • TugpsxTugpsx Posts: 751
    Nice, thanks for the prop. dropped in a Buddha for quick test in Octane.
    720 x 480 - 215K
    edited May 2014
    OK, I played with the stone texture and the bump texture, and I liked the bump texture better, so I used it for the Diffuse channel, and here's what I came up with. Not crazy about the lighting, but I did the best I could. Vicky looks lost in the room. :coolsmile:
    Be sure to click to see it unsquished.
    600 x 600 - 235K
    Post edited by Miss B on
