Render turns out fine, actor is totally white
in New Users
Hello,
Just like the title my render turns out fine, but my actor is white for some reason. I restarted my pc and reruning the same scene to be sure but any idea whats going on? This happens in a some parts of the scene, in others the actor renders out fine
Hello,
It could be the environment settings, or the lights I think. I was having similar problem till i went into render settings>environment and tweaked up some settings like intensity etc..
It could be that the texture isn't applied.
What render engine are you using?
Hey guys its in iray. Really buffled by this. I am also using a skydome, if it makes any difference. Just trying to understand they why and how of this
Skydomes are usually a 3Delight item as they have geometry and tend to block light, but as you can see the rendered image that's a (possible) problem for another day. If the figure is always white in the render then I'd suggest checking what shader(s) the figure uses as some of the custom shaders (such as AoA SSS) tend not to convert well for use by Iray.
This happens from time to time, the solution usually suggested is to delete the content of the following folder : C:\Users\AppData\Roaming\DAZ 3D\Studio4\Temp\Shaders\Brickyard but normally just closing DAZ and restarting it fixes the problem. If it doesn't I try again until it does.
