Render CPU _ GPU
good evening When I render using the iray engine if I select only the GPU (nvidia1060) does not render, however if I select the CPU and the GPU only the cpu renders the GPU at 0%. Can someone help me ? Thank you
good evening
When I render using the iray engine if I select only the GPU (nvidia1060) does not render, however if I select the CPU and the GPU only the cpu renders the GPU at 0%. Can someone help me ? Thank yougood evening
640 x 628 - 65K
1530 x 869 - 198K
676 x 521 - 9K
632 x 593 - 45K
Post edited by Chohole on
Make sure your Nvidia driver is up-to-date
Windows task manager is unreliable when it comes to GPU use. It will tell you that the GPU isn't used when it fact it is. At least with DAZ Studio, I don't know if it's a general problem or only a problem with DAZ.
