M4 & V4 not showing
Just purchased Poser 11 and after installing M4, V4 as well as other poser products I purchased here, they do not show I library. I have tried "File/Install from zip" and even manually placing the files myself and still do not show. Any help would be appreciated, haven't had much help from generosity on this.
What is that screenshot showing? Doesn't look like it displays the actual folders in your library, is that some kind of category/metadata view? (Actual question, as I don't have P11)
Ok, I was wondering since there are folders called "Figures" and "Poser Pro" in there...
Can you find the V4 or M4 cr2 on disk? Where is it located?
Poser 11 is a bit tricky.
In the main directory, I have several subdirectories
One of them is called Runtime.
Do NOT install content there, (apart from python scripts, these need to go there.)
I have installed my Poser Content folder within the Poser 11 main folder.(You may have installed it somewhere else; you get to choose the location when installing Poser 11)
In there, there is another Runtime folder.
And that is where all of the content goes.
Hope this helps,
