How this is made?
I had a FB commercial from daz3d and I want to know what filter is used for the image? Or something similar to achieve something like this.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,583
    edited June 2020
    that looks like a background image as the drops are not on the figure
    was likely done in a 2D image editor, GMIC which has a Gimp plugin has a filter like that
  • chris-2599934chris-2599934 Posts: 1,839
    What specifically is it about that image that you're trying to recreate?
    I agree with Wendy, it looks to me like she's been shot on a transparent background. See how the ends of the hair on the right side of her head are lighter than the background.
    Maybe a filter has been applied to the rendered image, maybe just some playing around with the levels. Hard to tell at that size.
    The background is a stock image of drips on glass, probably with the blue color added after.
    Then a vignette effect has been applied to the whole thing to get the darkening around the edges.
    That would be my guess, but you could ask the original artist here: https://www.renderhub.com/gallery/3823/unique-custom-character
  • What specifically is it about that image that you're trying to recreate?
    Sorry, I meant the woman. That cartoonISH look. Usually, my render a bit 'oily' or the faces are too generic, while this one has a bit more cartoon colors and you can see the age marks on it.
  • brainmuffinbrainmuffin Posts: 1,213
    If there was a way to up vote this, I would. I really like this question.
  • The Blurst of TimesThe Blurst of Times Posts: 2,410
    edited June 2020
    Uhhhhh... Cartoon filter in GIMP/PhotoShop? :-D
    I would use multiple layers. A Cartoon layer, obviously, which emphasizes the heavy black lines. An Oilify layer (oil painting effect) to get the (surprise) painted effect. And the base layer. All of these at different opacity/strengths. You may also want to erase sections where you don't want cartoon or oilify or whatever. The point is to blend it into the effect that you want.
    You may want a desaturated layer. You likely will need some color correction work because you ALWAYS should adjust tone and color on photos, IMO.
    Just take it into GIMP (or Photoshop) and play. That's the best way to do it.
    Post edited by The Blurst of Times on
  • SteveM17SteveM17 Posts: 985
    It's never occured to me to use different filters on different layers and alter the opacity in GIMP. Definately going to give that a try! Cheers.
  • scorpioscorpio Posts: 8,479
    edited June 2020
    SteveM17 said:
    I sometimes use several different layers with different filter effects at different opacities. These were done using filters and have a similar look.
    1414 x 2000 - 3M
    2264 x 3200 - 6M
    Post edited by scorpio on
    Nice pics.
    I've loaded my picture as a few layers in Gimp, but for some reason when I apply a filter to a layer I can't switch to the other layers, even though I click on them in the layers menu box. I'm sure I'm doing something stupid.
