Invalid node selection for "preset_material" type
I am confused by this [Invalid node selection for "preset_material" type] error I am getting.
If I understand right it seems like the complaint that I am attempting to add a skin to an object and don't have the right object selected. But it is a prop, magazines specifically. It even lists Material(s) at the top and IRAY at the bottom. I don't see this without a skin option.
This is the source: https://www.daz3d.com/the-werks-mega-prop-pack
Which combination of item, selection, and preset is doing this? Is that the fulll message?
(178): recv failed errno=10054
2020-06-05 13:23:40.767 Invalid node selection for "preset_material" type.
2020-06-05 13:23:40.767 Error reading file, see log for more details.
I tried to have the item I wanted it on to appear on selected, then I tried without having anything selected. Usually, everything just centered.
Sorry this took so long. These were the 2 items I tried. Double clicked to get the error and also tried dragging it into the scene.
I hope this is what you needed.
Ok, but which model was selected? (And I can't read the name of the second preset under the note.)
Sorry, I'm confused. What do you mean by model?
When I first tried I had a bookshelf selected, hoping it would put it as a child of the bookshelf, but then I tried it with everything deselected and still got the same error. Then I tried just the single magazine and got the same error.
I added the same image without the markups. I didn't realize it was important. If I am missing some information, what exactly am I missing that you would need?
TWMP Magazine Stack if that helps
Ah, I figure it out. I was supposed to select prop. I never saw the item in the prop folder before. I thought this was the whole thing, not just a skin.
And this is why I post in the new user forum.
