Character meshes and their compatibility
I'm mystified. There are the basic character meshes: G8F G8M, G3F, G3M, etcetera. And there are character meshes described as compatible with those basics but referencing a third character mesh as well. For example. Given G8F, there is a character mesh named Sahira 8 (which I presume requires G8F) and yet another named Tristana for Sahira 8. Now Tristana is listed as compatible with G8F. I don't know how to interpret that. Can I simply apply Tristana to G8F, which seems to be suggested, or must I have Sahira 8. In short, in order to use Tristana, must I first open G8F, apply Sahira 8, and then apply Tristana for Sahira 8, which also seems to be suggested?
  • fixmypcmikefixmypcmike Posts: 19,612
    Tristana's skins will work on G8F.  The morph requires Sahira to look exactly as in the promos, but it will work on just G8F without Sahira.  It will look a little different.
    You don't have to take an extra step -- when you load Tristana it will set the Sahira dial as well (if you have it).
  • contedesfeescontedesfees Posts: 279
    edited June 2020
    Fixmypcmike, I think I'm coming to depend on your sage wisdom. Thanks yet again.
    Post edited by contedesfees on
