Problem with controls from array created with getChildrenOfWidget()
ruekakaruekaka Posts: 346
Hello.
I stumbled into a strange problem when using getChildrenOfWidget() to get the controls of a form.
(I didn't test all types yet, but I found 3 types where I can't get the value of the control)
I create 3 prompts of the following types: DzFloatSlider, DzIntSlider and DzColorWgt
When I access the objects direct it works as expected (although the class name is different):
ce_test_prompt_3: [object Object] (Class name: DsColorWgt) [x:216, y:250, w:560, h:24 || value.name: #256997] (Name: ce_test_prompt_3)
ne_test_prompt_4: [object Object] (Class name: DsIntSlider) [x:216, y:275, w:560, h:26 || min: -100, max: 100, value: 77 (Name: ne_test_prompt_4)
ne_test_prompt_5: [object Object] (Class name: DsFloatSlider) [x:216, y:305, w:560, h:26 || min: -1000, max: 1000, value: 12.34000015258789 (Name: ne_test_prompt_5)
But when I use getChildrenOfWidget() and pick the 3 controls from the array I get the following:
control: [object Object] (Class name: DzColorWgt)[<<<-Result of expression 'theVar.value' [undefined] is not an object.->>>] (Name: ce_test_prompt_3)
control: [object Object] (Class name: DzIntSlider) [x:216, y:275, w:560, h:26 || min: undefined, max: undefined, value: undefined (Name: ne_test_prompt_4)
control: [object Object] (Class name: DzFloatSlider) [x:216, y:305, w:560, h:26 || min: undefined, max: undefined, value: undefined (Name: ne_test_prompt_5)
The (e.g.) text property of a line edit control or the checked property of a checkbox show the correct value when picked from the array.
How can I access the values from the controls taken from the array?
Any hint is highly welcome.
With kind regards,
Ruediger Kabbasch
Post edited by Chohole on
    There really isn't enough context to offer anything
  • ruekakaruekaka Posts: 346
    edited June 2020
    O.K., I thought I described all the details blush
    Anyway, I created the most simple example to reproduce it:
    // DAZ Studio version 4.12.1.117 filetype DAZ Scriptvar m42Maindialog = null;var textEdit      = null;var colorEdit     = null;var doubleEdit    = null;var integerEdit   = null;var lineEdit      = nullvar buttonTest    = null;(   function()   {      PrepareMainDialog("Array tester", 800, 600);      m42Maindialog.exec();   })();function PrepareMainDialog(formCaption, width, height){   m42Maindialog            = new DzDialog;   m42Maindialog.name       = "m42_main_form";   m42Maindialog.caption    = formCaption;   m42Maindialog.width      = width;   m42Maindialog.height     = height;   m42Maindialog.minWidth   = width;   m42Maindialog.minHeight  = height;   m42Maindialog.maxWidth   = width;   m42Maindialog.maxHeight  = height;   buttonTest = new DzPushButton(m42Maindialog);   buttonTest.text      = "Run Test";   buttonTest.name      = "buttonTest";   buttonTest.width     = 200;   buttonTest.height    = 24;   buttonTest.x         = 10;   buttonTest.y         = 10;   connect(buttonTest, "clicked()", testButtonClick);      lineEdit = new DzLineEdit(m42Maindialog);   lineEdit.text      = "Text value";   lineEdit.name      = "lineEdit";   lineEdit.width     = 780;   lineEdit.height    = 20;   lineEdit.x         = 10;   lineEdit.y         = 40;      colorEdit = new DzColorWgt(m42Maindialog);   colorEdit.name      = "colorEdit";   colorEdit.width     = 780;   colorEdit.height    = 20;   colorEdit.x         = 10;   colorEdit.y         = 70;   colorEdit.value     = Color(37, 105, 151);      integerEdit = new DzIntSlider(m42Maindialog);   integerEdit.name      = "integerEdit";   integerEdit.width     = 780;   integerEdit.height    = 20;   integerEdit.x         = 10;   integerEdit.y         = 100;   integerEdit.value     = 77;   integerEdit.min       = -100;   integerEdit.max       = 100;   doubleEdit = new DzFloatSlider(m42Maindialog);   doubleEdit.name       = "doubleEdit";   doubleEdit.width      = 780;   doubleEdit.height     = 20;   doubleEdit.x          = 10;   doubleEdit.y          = 130;   doubleEdit.value      = 123.465;   doubleEdit.min        = -1000;   doubleEdit.max        = 1000;   doubleEdit.sensitivity = 0.5;   textEdit = new DzTextEdit(m42Maindialog);   textEdit.text      = "";   textEdit.name      = "textEdit";   textEdit.width     = 780;   textEdit.height    = 410;   textEdit.x         = 10;   textEdit.y         = 160;}function WriteControlInfo(theControl){   var curInfo      = "[--- I G N O R E D ---]";   var curClassName = theControl.className();   try   {      if ((curClassName == "DzWidget") || (curClassName == "DzTabWidget"))      {         curInfo = " ["                 + "x:" + theControl.x                 + ", y:" + theControl.y                 + ", w:" + theControl.width                 + ", h:" + theControl.height                 + "]";      }      else if ((curClassName == "DzIntSlider") || (curClassName == "DzFloatSlider") || (curClassName == "DsIntSlider") || (curClassName == "DsFloatSlider"))      {         curInfo = " ["                 + "x:" + theControl.x                 + ", y:" + theControl.y                 + ", w:" + theControl.width                 + ", h:" + theControl.height                 + " || min: " + theControl.min                 + ", max: " + theControl.max                 + ", value: " + theControl.value                 + "]";      }      else if ((curClassName == "QLineEdit") || (curClassName == "DzLineEdit"))      {         curInfo = " ["                 + "x:" + theControl.x                 + ", y:" + theControl.y                 + ", w:" + theControl.width                 + ", h:" + theControl.height                 + " || text: " + theControl.text                 + "]";      }      else if (curClassName == "QCheckBox")      {         curInfo = " ["                 + "x:" + theControl.x                 + ", y:" + theControl.y                 + ", w:" + theControl.width                 + ", h:" + theControl.height                 + " || checked: " + theControl.checked                 + "]";      }      else if ((curClassName == "DzColorWgt") || (curClassName == "DsColorWgt"))      {         curInfo = " ["                 + "x:" + theControl.x                 + ", y:" + theControl.y                 + ", w:" + theControl.width                 + ", h:" + theControl.height                 + " || value.name: " + theControl.value.name                 + "]";      } //&lt;- if (theControl.className == "DzWidget")   }   catch (Exception)   {      curInfo = "[&lt;&lt;&lt;-" + Exception.message + "-&gt;&gt;&gt;]";   }   curInfo = "Name: " + theControl.name + ", Class name: " + curClassName + " || " + curInfo;   textEdit.append(curInfo);}function testButtonClick(){   textEdit.clear();   WriteControlInfo(textEdit);   WriteControlInfo(colorEdit);   WriteControlInfo(doubleEdit);   WriteControlInfo(integerEdit);   WriteControlInfo(lineEdit);      textEdit.append("");   curControls = m42Maindialog.getChildrenOfWidget();   for (iControl = 0; iControl &lt; curControls.length; iControl++)   {      if (curControls[iControl].name.length &gt; 0)      {         WriteControlInfo(curControls[iControl]);      }   }}
    An example output is attached as a screenshot
    670 x 233 - 32K
    Post edited by ruekaka on
  • andya_b341b7c5f5andya_b341b7c5f5 Posts: 694
    edited July 2020
    I don't have a solution but agree something is odd.
    I have been trying to use a DzColorWgt and found that the object returned by the DzColorWgt constructor has a className  of DsColorWgt and says it inherits from DsColorWgt.  This has a property 'value' which is initialized as a Color object (255,255,255), and can be  updated.
    If you attempt to retrieve this widget using getWidget(), or [DzDialog].getChildrenOfWidget() you will get an object that has a className of DzColorWgt.  More importantly, the object does not have the property 'value' now.  I would not be surprised at all if the same is true of findChildOfWidget().
    (   function()   {	  var dummyDialog = new DzBasicDialog();	  var DzClrWgt = new DzColorWgt(dummyDialog);	  DzClrWgt.name = 'DzClrWgt';	  if (DzClrWgt.hasOwnProperty('value')) {		  print('Initial value: = ', DzClrWgt.value.red, DzClrWgt.value.green, DzClrWgt.value.blue);		}	  DzClrWgt.value = Color(100, 50, 0);	  DzClrWgt.col = Color(101, 50, 0);	  print('DzClrWgt: className = ', DzClrWgt.className(), ' name = ', DzClrWgt.name, 	  	'objectName = ', DzClrWgt.objectName);	  print('DzClrWgt proto ', DzClrWgt.prototype, DzClrWgt.__proto__.name);	  print('DzClrWgt.value = ', DzClrWgt.value.red);	  if (DzClrWgt.hasOwnProperty('value')) {	  	print('DzClrWgt has own prop value');	  }	  if (DzClrWgt.hasOwnProperty('col')) {	  	print('DzClrWgt has own prop col');	  }	  	  print('Enumerable properties...');	  for (var p in DzClrWgt) {	  	if (p == 'value' || p == 'col') {		  	print(p, DzClrWgt[p])		  }	  }	  print('Enumerable and non-enumerable propertes found directly on object...');	  var arr = Object.getOwnPropertyNames(DzColorWgt)	  var ownprops = arr.filter(	  	function(x) 	  	{ 	  		if ((x == 'value') || (x == 'col')) {return x}; 	  	}	  )	  ownprops.forEach(	  	function(x) { print(x) }	  )	  	  if (DzClrWgt.inherits('DsColorWgt')) {	  	print('DzClrWgt inherits DsColorWgt')	  }	  	  var w = DzClrWgt.getWidget();          print('DzClrWgt.getWidget: className ', w.className(),       	      ', value = ', w.value,       	      ', name = ', w.name);      	          print('DzClrWgt.getWidget props: ');	  if (w.hasOwnProperty('value')) {	  	print('w has own prop value');	  }	            for (var p in w) {      	  if (p == 'value') {		  	print(p, w[p])		  }	  }	  var ownprops = Object.getOwnPropertyNames(w)	  ownprops.filter(	  	function(x) 	  	{ 	  		if (x == 'value') {return x}; 	  	}	  )          try {	      print('w.value ', w.value.red);	      }	  catch(err) {	  	print('w.value - ', err);	  }	  print('getChildOfWidget props');	  var chArr = dummyDialog.getChildrenOfWidget('DzClrWgt');	  chArr.forEach(		function(x) {			print(x.name, x.className(), x.objectName)		}	  )	  try {		print(chArr[0].value.red);	  } catch(err) {		print('w.value - ', err);	  }   })();
    Executing Script...
    Initial value: =  255 255 255
    DzClrWgt: className =  DsColorWgt  name =  DzClrWgt objectName =  DzClrWgt
    DzClrWgt proto  undefined undefined
    DzClrWgt.value =  100
    value [object Object]
    col [object Object]
    value
    col
    DzClrWgt.getWidget: className  DzColorWgt , value =  undefined , name =  DzClrWgt
    w.value -  TypeError: Result of expression 'w.value' [undefined] is not an object.
    DzClrWgt DzColorWgt DzClrWgt
    w.value -  TypeError: Result of expression 'chArr[0].value' [undefined] is not an object.
    Result:
    Script executed in 0 secs 21 msecs.
    Post edited by andya_b341b7c5f5 on
