Photoshop
hermun81hermun81 Posts: 101
Install Manager cannot find a required path. The package for "Ron's Splashes" requires that the installed path for "Photoshop CS6, CS5, CS4, CS3, CS2, CS, 7" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
I don't even know what this means...
  • prixatprixat Posts: 1,590
    That's in settings...
    Either add a path (marked as 3) or correct the existing path.
    935 x 836 - 119K
  • jaxprogjaxprog Posts: 312
    Prixat is correct with the path in setting, however these path settings are useful to Daz Stuidio where Photoshop bridge is concerned. In my experience in dealing with these brushes, because I have purchased many of them, DIMM downloads the brushes in a zip file but does not unzip them and put them in your preset brushes folder for Photoshop to use. You will have to manually unzip it, copy/cut then paste the abr files into your Photoshop preset-brushes folder to use them. In addition some of Ron's packages include other types of file such styles, and so you would put those in the present styles folder. Lastly some of Ron's packages come with jpgs like backgrounds where you can put those files anywhere you want such as your documents or pictures folder.
  • Richard HaseltineRichard Haseltine Posts: 102,764
    The Brushes will be unzipped if you have a path for Photoshop set (and choose to install, of course) - the system is, however, a little annoying as I prefer to keep my brushes in an external folder rather than in the PS application folder so I have to move them after installing or manually unzip (if you don't want to install the PS Bridge for DAZ Studio you can always set the PS path to an external folder for brushes). I should make a feature request to have separate paths for plug-ins and content.
