[Released] Props and Poses Converter from Genesis 8 Female to Genesis 3 Female [Commercial]
RiverSoft ArtRiverSoft Art Posts: 6,637
Easily use your Genesis 8 Female props, accessories and poses for your Genesis 3 Female characters. Automatically convert almost your entire library of props, accessories, and poses using the Props and Poses Converter for Genesis 3 Female. The Props and Poses Converter script provides batch execution for automatically converting your Genesis 8 Female props, accessories and poses to Genesis 3 Female props, accessories and poses in your library. Easily select the Genesis 8 Female props and poses in your library, select an output directory, and execute the script. Even better, icons and categories are copied from your Genesis 8 Female prop or pose to the new Genesis 3 Female prop or pose.
Your new Genesis 3 props, accessories and poses are completely Smart Content-aware. They will show up when you select a Genesis 3 Female. Plus, all materials shown in Smart Content for your Genesis 8 Female prop or accessory will show for your converted Genesis 3 Female prop or accessory.
The Props and Poses Converter script does not work with multi-part props (e.g., two daggers are loaded from the same preset). Items without metadata can be converted but will not show up in Smart Content. They may also need to be converted using a Force Convert Item(s) button. Zero Poses are not converted.
  • Convert Genesis 8 Female props and accessories for use by Genesis 3 Female characters.
  • Convert Genesis 8 Female Posed Props (e.g., Hand Gripping a Sword) to Genesis 3 Female Posed Props
  • Convert Genesis 8 Female Poses to Genesis 3 Female Poses
  • Convert Genesis 8 Female Hierarchical Poses to Genesis 3 Female Poses*
  • Convert Genesis 8 Female Expressions to Genesis 3 Female Expressions (Limited)**
  • Convert Swords, Bows, Glasses, Jewelry, etc.
  • Convert Accessories: Hats, Belts, Glasses, Jewelry, etc.
  • Copies icons from Genesis 8 Female Presets to Genesis 3 Female Presets for a professional look
  • Converted Items are Smart Content enabled! All materials shown in Smart Content for your Genesis 8 Female props and accessories will show for your converted Genesis 3 Female props and accessories.
  • Automatically convert almost your entire library of props, accessories and poses with one operation!
Due to a limitation in the Daz Studio script interface, Hierarchical Pose Presets are converted to regular poses, and only for the figure, with this tool. For example, hierarchical poses that "grip" a sword will become regular grip poses. However, hierarchical poses of a figure and wings will only retain the pose for the figure and any movement of the wings will not be converted.
Expression values are converted however, expression morphs are not. Since morphs are not converted, the expressions will not be identical between Genesis 3 and Genesis 8. Also, if the equivalent expression name does not exist in Genesis 3, nothing is converted, though name mappings have been defined for the most common and may be extended (please see About Pose Controls in the manual).
What's Included and Features
  • Props & Poses Converter from Genesis 8 Female to Genesis 3 Female:
    • Props & Poses Converter Script (.DSE)
    • Detailed user Guide (.PDF)
1000 x 1300 - 540K
1000 x 1300 - 581K
2000 x 2363 - 1M
1000 x 1300 - 561K
1000 x 1300 - 539K
1000 x 1300 - 318K
2000 x 2363 - 1M
1000 x 1300 - 381K
1000 x 1300 - 855K
Post edited by RiverSoft Art on
