Poser and File Corruption
Has anyone discovered that assets for Poser, for example Michael 4 files and related character morphs, become corrupted and function oddly? Tonight I discovered that none of my M4 character morph head or body inj files would work. Srangely, the mat files for the various characters, when applied to M4, injected both their corresponding head and body. Deleting the prefs files as Poser recommends for unusual behaviour only resulted in more aggravation. Poser ran but could not open the default PZ3. It simply hung until I gave up. Has anyone had a similar experience, and if so what did you do about it? Thanks very much.
  • WandWWandW Posts: 2,846
    Did you initialize the morphs after installing M4 and his morphs?  DIM does it automatically, but it has to be done manually if you install from zips.
    Also, having duplicate M4 CR2s in your library can cause problems...
  • contedesfeescontedesfees Posts: 279
    Thanks for yours, WandW. There was nothing to do but to re-install the beast tooth, claw, and tail. I started early this morning and have just finished. Things look to be working. Thanks again.
