My first two stumbling blocks
Hello,
I have run into two issues with Daz that I could use some insight on. First one, every time I upload the Genesis 3 Female actor she comes in with an overbite. The second one is that I'm using SC Mia Hair, but the colors all come in "frosty". This is supposed to be red hair. I have attached a photo for reference.
Any assistance will be greatly appreciated.
Thank you,
Kurt
  • Richard HaseltineRichard Haseltine Posts: 102,716
    If Genesis 3 Female Base is loadign with an odd shape check the Currently Used group in the Parameters pane - probably something was saved with a non-zero default value.
    Are you renderiing in Iray or 3delight? Which presets are you applying to the hair?
  • FSMCDesignsFSMCDesigns Posts: 12,780
    As for the overbite, looks like you have a morph that is constantly loaded which happens something. Select the figure and then in the parameters tab check the currently uses section at the top and see what morphs are loaded and zero them out, make note of the one that caused this and send in a support ticket so it can be fixed.
    As for the hair it loads fine for me, have you tried applying any of the 18 textures it comes with? Also make sure you have everything installed. Unlike here, renderosity likes to break up the files in multiple zips.
