A couple of Questions
boewjrboewjr Posts: 0
1 How do you remove the checkboard background when you render a scene
2 Can you import an entire Poser Runtime into Daz?
Thanks
Oscar
  • Richard HaseltineRichard Haseltine Posts: 102,712
    The checkerboard iis showing the areas which lack anything to render - if you save as a Tiff or PNG they willl be  transparent, or unselected in the alpha channel, if you save in a format like JPG that doesn't support masks they willl be filled with black.
    The quickest way is to right-click on Poser Formats in the Content Library pane, select Add runtime Directory, and select the folder that contains the Runtime folder (e.g. Poser 11 Content)
    boewjr said:
    Thanks
    Oscar
