morph++ not working, help?!
saphiragoresaphiragore Posts: 0
So I downloaded michael base and michael morphs ++ and the morphs are not loading into the character?
I select morph injections>base> and select a +shape but nothing is showing up on the character. Iv tried selecting the whole body, just the mouth, face but nothing is working?
Im not sure what Im doing wrong if someone could please help me that would be great. thanks
    Clicking on the morph injection just activates the dial in the figure. You then need to go to the Parameters pane and dial the morph to the desired strength.
  • saphiragoresaphiragore Posts: 0
    I have michael base and michael morph ++
    when I load michael base and try to add morphs nothing happens
    Im clicked on region nav > select base >morph injections>base>eyes/face/mouth nothing happens I even tried selecting the head and try to click on a morph and nothing is happening I'm really confused? help please?
    Are you using Poser or D/S? When I load M4 in D/S there's a dialogue that comes up for me to select all the ++ to load.
    At any rate, once injected, when the appropriate body part is selected, the available morphs should be listed on the Parameters Tab.
    One dials them in as desired.
    http://www.daz3d.com/forums/discussion/41888/
    Welcome to the forums! Normally we post any one question once in any forum thread. If one wants the thread moved to another area, one can send a moderator a PM to that effect ;-)
  • Richard HaseltineRichard Haseltine Posts: 102,768
    Merged threads and moved to new users forum.
  • JaderailJaderail Posts: 0
    edited May 2014
    First Morphs++ do not change the Figgure by applying them to the figure. That step only adds the morph to the list of injected morphs if the figure and morph set is installed properly and the Morph channels have been activated, DIM should have auto done that step. Once the user has applied a morph++ file to the figure you must then open the figure in Parameters and find the now Injected morph in the proper section of the figure and then Dial the morph to a setting.
    They do not auto change the figure, you need to dial as much or as little of the morph to be used yourself.
    Post edited by Jaderail on
