mcjstareatthecam - script for Daz Studio 1, 2, 3, 4 - static or animated stare-at-the cam effect - w
mCasualmCasual Posts: 4,607
edited July 2014 in Freebies
ze script --> https://sites.google.com/site/mcasualsdazscripts4/mcjstareatthecam
ze movie --> https://www.youtube.com/watch?v=n7EDW5WxpT8
select the figure's head
launch the script
select the range of frames that will be processed
you may also apply a delayed reaction to the follow-movement
if your animation is a loop, and you use a delay, then you should turn on the loop option
800 x 450 - 204K
800 x 450 - 230K
1280 x 720 - 636K
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    sorry about the 2 megs bandwidth
    480 x 270 - 2M
  • ShayneShayne Posts: 18
    thanks for this! works great!:smirk:
  • cwichuracwichura Posts: 1,042
    I am a bit late to the game, having only now noticed this script. First, thanks for this. Using 'Point at' on the eyes doesn't always seem to work well.
    Have you considered looking into hooking this up to any of the other facial features for the eyes? I did my testing with G2F, and it only rotates the eyes, whereas the Pose Control for eye movements also moves the eye lids/etc. The script resulted in some pretty freaky looking eyes depending on camera placement when the eyelids weren't tracking along... :)
    it should be ready tonight
    i'll make it a separate script named mcjStareAtTheCamG2F
    618 x 800 - 291K
    edited July 2014
    Aiko5 morphs and BlenderCycles render
    The script makes both eyes point at the camera lend but possibly, they should look at parallel angles
    this is mostly an issue for close-ups
    also it seems to miss the target
    i'll improve all this
    606 x 762 - 92K
    604 x 772 - 50K
    618 x 800 - 131K
    Yeah, this would be cross-eyed in closeups. Maybe compute the center point between the two eyes (so somewhere behind the bridge of the nose), calculate the look vector from that and then apply it to both eyes? Or add it as another option to your dialog: crosseyed/centerpoint/useleft/useright for calculating the look vector for the ultimate user flexibility... :)
    And thanks for taking my suggestion about the other facial posing to heart so quickly!
    edited July 2014
    i'll project the eyes perpendicular to a plane at the location of the camera
    that plane faces the figure ( its normal going from the camera to the midpoint between the eyes )
    i guess the eyes were looking AT the camera and they need to point "in the direction" of the camera
    606 x 776 - 90K
    well the difference is not really noticeable
    note that the figure's face is "pointing" elsewhere
    so to really get the feeling she's looking at you
    and not at mister Jones, you'd have to turn the
    face too using my mcjLookAtTheCamera script
    1600 x 1200 - 618K
    How about just a head shot, though, as then the camera would be quite close (assuming you don't change its field of view to make it into a telephoto lens)? That's where having the parallel vectors would be most beneficial, I believe.
    edited July 2014
    facing the face
    next render will be a close up,
    588 x 754 - 74K
    741 x 960 - 180K
    edited July 2014
    the extreme close up doesnt look excessively cross eyed
    but lets see
    fig 3 i made the eyes look parallel ( manually )
    well i think i'll leave it like that, both eyes pointing at the camera
    i'm surprised it's not more noticeable than that
    ... though in the A/B image its detectable
    600 x 600 - 95K
    741 x 960 - 286K
    552 x 730 - 79K
    741 x 960 - 286K
    edited July 2014
    well in the end ... i will include it as an option :)
    note that this is a pretty extreme close-up that may cause papparazzis to acquire a bad reputation
    741 x 960 - 437K
    741 x 960 - 438K
    notice the new "parallelize" checkbox
    i'll do a few tests and post it
    ( and things )
    990 x 602 - 238K
    oh my wayyyyy better with a longer lens ( 180mm )
    her hair could use a bit of a volumizer
    on the other hand she looks a bit more like a medieval hero or something
    and there just are not many hair salons in the woods
    741 x 960 - 177K
    by making the eyelids processing optional i can make this the new version
    if the figure is not like Genesis 2 in refard to the eyelids, then eyelids processing will be detected and not attempted
    still the stare-at functionality and the parallelize option will be operational
    1010 x 610 - 249K
    edited July 2014
    ** New Version **** New Version **** New Version **** New Version **
    many thanks go to - cwichura - for suggesting the new Genesis eyelids feature
    tomorrow 'll update the manual to explain the 2 options though it's all explained in the forum posts preceding this one )
    741 x 960 - 177K
    Many thanks for this. Just woke up, so missed a bunch of your updates last night. I'll definitely give this a try today once my brain actually starts up...
    Just gave it a try and it seems to be working quite well. Again, thanks for this.
  • RAMWolffRAMWolff Posts: 10,222
    This could be very useful. Does it work on the Gen2 males?
    if the eyelids close morph has the same name it may work !
